plastic wheel arch liners
impala
Hi,
2001 2.2 facelift - Just noticed that one of the front wheel arch liners is loose. Probably figure it out myself when I get the wheel off but can anyone bring me up to speed on how these are supposed to be secured?
Many thanks,
Dave
Titan
Moderator
North North Yorkshire
sDrive35i
From memory it's a selection of 10mm hex head screws and a variety of fiendish BMW body clips. These are like mushrooms with a centre pin that self-destruct as soon as you touch them. Good news is they are only about 19p each from the dealer :)
Sent from m'iPhone using Tapatalk
billz
Langley Mill
Yep just as Titan says. Very easy to get off but a pig to reseat as there is no real flex in the new ones. When you put them on make sure you get it tooked correctly at the back of the lip of the sills
bill
Titan
Moderator
sDrive35i
You may be lucky Dave, THIS OEM LINK suggests that all the fixings are screwed rather than mushroom rivets.
I used our car in this example but if you put the last 7 digits of you chassis number in to THIS PAGE, you should get the exact details for you Zed.
It should be under Group 51 SubGroup 75 Mounting Parts Engine ompartment
If you get stuck with OEM, let us know ;)
Derick Mills
RETFORD
2.8i
IMG_0338.JPG I striped down a while ago now and didn't take photos of where things went so can someone help as to where this goes
Derick Mills
RETFORD
2.8i
Please
DrWong
3.0i
Back of the wheel arch, behind the wheel arch liner. It covers a gap in the chassis. I believe that’s the passenger side one. The holes on the right allows wires to pass through, including the wire for the side indicator
Derick Mills
RETFORD
2.8i
Thanks very much all done now
Those 8mm headed self tappers soon go rusty, same ones on my wing liners on the Z4 I have, they are quite visible on the outer edge and it niggled me every time I looked at the car. Ended up finding some compatable stainless screws on ebay and some stainless washers to increase the screw head size which have now been fitted to mine front and rear.
Screws I used were here https://www.ebay.co.uk/itm/3-5mm-4-...var=632025528956&_trksid=p2057872.m2749.l2649
Washers here https://www.ebay.co.uk/itm/M4-M5-M6...var=622192733929&_trksid=p2057872.m2749.l2649
