...have you wrapped the exhaust manifold as well, maybe missed it?
No. I did consider ceramic coating, or exhaust wrap, but I read that this is really a thing for race cars.
It would be a good modification on a mild steel system, but stainless steel is prone to heat cracking, and I would rather not have that problem.
More stuff to think about...
Suck and Blow seem to attract the most modifications, as they are easy for an amateur, and they are external. Squeeze and Bang are just as important, but they are much more difficult for us amateurs to improve.
The easiest way to improve Squeeze and Bang is to adjust the valve clearance correctly.
Tight valve clearances, but in tolerance = Valves opening to designed maximum lift and maximum time, but still closing properly.
Tight valve clearances, but out of tolerance = Valves may not fully close, leading to escaped gases and valve seat burning.
VERY BAD.
Loose valve clearances, but in tolerance = Valves fully open 0.05mm less than design maximum, and is open for less time than design maximum.
Loose valve clearances, but out of tolerance = Valves will not open as far, or for as long as designed, but valves are guaranteed to close.
This shows the valve opening and closing times for the S50B32.
Hopefully, you can imagine the effect of the segments being a few degrees longer or shorter. I thought I had done the actual measurements of different shims, but all I have are the actual measurements of the camshafts (Exhaust = 47.19/36.25, Inlet = 47.18/36.00)
This means that the exhaust valve can open between 10.61mm and 10.66mm, and the inlet valve can open between 10.95mm and 11.00mm. The simple maths of cylinders makes you think this is only a 1% improvement, but it's more than that. You have to include the extra time the valve is open, and the corresponding increase in area under the "Bell Curve".
