Had a K&N 57i Induction kit on my 2.8, the whoooooosh sounded great but that's about it, it definitely went better on returning to stock.K&N, Pipercross etc ..anyone fit one..are they worth it, if so what’s best for an M54 ?
You are not wrong about the Bernoulli Effect causing a negative pressure, but it would be miniscule relative to the "sucking effect" of six cylinders consuming over a million litres of air per minute at full chat. On the other hand - every little helps.Curious… the air intake inside the brake duct looks like the pressure would be negative pressure… like venturi. Has anyone put a lip on front edge or scoop on back side of this orifice… to push air into the air box or cone filter downpipe?
The attached photo is looking up… where intake duct is recessed into duct. Thanks.
Didn't you do a bench test on performance oiled filters vs stock paper filters some time ago?You are not wrong about the Bernoulli Effect causing a negative pressure, but it would be miniscule relative to the "sucking effect" of six cylinders consuming over a million litres of air per minute at full chat. On the other hand - every little helps.
I have thought about it, but never done it. It could be a project for the summer.
I have a manometer port on my air box, so I could measure the pressure at a set speed with and without the modification.
I'm not sure how critical brake temperature is. If it is close to critical, it could be the limiting factor.
The problem with speed-related induction pressure is that the fuel management is based on anticipating the fuel requirement at a particular engine condition (rpm / throttle position / torque demand / engine acceleration). If you have a car accelerating at full throttle (WOT) in 1st gear, the air pressure is less than a very similar engine condition in 2nd and 3rd gear.Manometer! More gauges…. That’s fun.
I wouldn’t block the duct… I was thinking a lip on front edge or scallop on back edge for directing air in.
Mikes write-up is very good, but not sure it’s M as my filter box is different? Also like the use of word “wend”, as describing air migration through ducts. Good stuff.
Yes. BMW paper filter is the best.Didn't you do a bench test on performance oiled filters vs stock paper filters some time ago?
My thoughts - and they are probably wrong....I thought MAF measured Mass of Air to compensate for barametric and air density? This is coupled with Temperature to determine mixture and O2 sensor will determine if the mixture is burning efficiently. So… if we jam more air pressure, one gets more flow through heads and more everything is more HP. The air induction model, therefore yields more efficiency over non-induced flow.
While I don't map ECU for money, I did flip my air cleaner lid on Oldsmobile 455ci engine as young man and it was glorious.
Thought so, went back to a paper filter from a K&N on the M after reading it.Yes. BMW paper filter is the best.
The improvement that I made was to modify the internals of my airbox.
The improvement was from 444CFM to 485CFM ay 28"H2O
Air Filter Box Modification
Looking at the intake system of the M Roadster, I thought that the air filter box could do with some improvement... I built a flow bench to measure the flow rate through the air filter box... but this rig would only measure comparative differences. So, I built another rig. The data from...www.zroadster.org
