- Joined
- Feb 18, 2016
- Points
- 231
- Model of Z
- Z3M Imola and Z4 (e89)
Why do you disagree Tony? I have seen the rubber covers on fleabay and these obviously don't fit the the pedals with them removed
I agree and didn't say you should, I just said you can buy them and I think this is the type he has.You should not mount these on top of the original rubber anti-slip pads. Bad idea.
I'm not sure what you mean Niall. I just meant you shouldn't mount the alloy pedals on top of the original rubber pads. Anyway I managed to drill my pedals and fitted the screws and nuts.Why do you disagree Tony? I have seen the rubber covers on fleabay and these obviously don't fit the the pedals with them removed
Sorry Nodzed they are most definitely not to go on top of the rubbers it would be very dangerous since you would run the risk of the whole lot coming off when pressing pedal not cool on brake.I think you will find the ones you have there are designed to fit on top of the rubbers not to replace them, thats why the holes are in the wrong place. you can get either.
Well thats good then, as I said you can buy both. glad you got the correct onesSorry Nodzed they are most definitely not to go on top of the rubbers it would be very dangerous since you would run the risk of the whole lot coming off when pressing pedal not cool on brake.
