Are the two ends of the cables connected at the seat rails ?
Yep everything is connected correctly, both seats have the exact same problemAre the two ends of the cables connected at the seat rails ?
Everything looks well routed & securely fixed, all cable ends are located correctly including both nipples in the clips properly at the mechanism endsCan you post a picture of the cable routing? Unless they've been changed? at any time it must be the routing because Bowden cable can't stretch.
Are the outer cable sleeves secured on the seat frame? If they're secured with a clip, can the clip be released and the outer sleeve moved to take out some slack then the clip be re fixed?Everything looks well routed & securely fixed, all cable ends are located correctly including both nipples in the clips properly at the mechanism ends![]()
Don't worry, Friday night you'll have all the parts you need. See you then mate.Everything looks well routed & securely fixed, all cable ends are located correctly including both nipples in the clips properly at the mechanism ends![]()
It certainly doesn't appear that its possible to do that Tony, be great if it has threaded collars like pushbike brakes
Yes that's how I managed to test it on the drivers seatCould be a simple fix then Tony
@Perkio do you now have the motor out of the seat
Might be able to talk you through trying to fix itYes that's how I managed to test it on the drivers seat
Does look the easiest thing to get into & I'm not the most patient person I know! Time I've finished with it it'll be scrap for sure as anything electrical is usually my nemesisMight be able to talk you through trying to fix it
I'm going to see Andy Friday to pick up a motor so I can get the car back on the road, but I'd happily send the old one to you & pay you if you can fix it for me & so I have a spare if I ever need it, cheers SteveWell if you plan to replace it.
I would be interested in taking the broken one off your hands to open up see if repairable.
