- Joined
- Apr 27, 2012
- Points
- 100
Nope - it has a random rolling code handshake with the DME. The code changes every time you switch off the engine.
It's all part of the anti-theft system. Apparently, when you replace the EWS with a new module the rolling code has to be re-set to #1 in the DME and then the process of verification between the EWS and the DME is synchronised by the codes from there onwards. Added to that, the EWS has to be coded to your car VIN number.
The problem with trying to replace just the EWS from another vehicle is that the rolling code will not match the last code set in the DME.
The only way to replace the EWS with a second hand ews is to also replace the DME and the key and key barrel from a similar year / model car. All the components being replaced must come from the same donor car since that ensures that the EWS and DME are matched in terms of the rolling codes, and the key and EWS are matched in their coding too. The replacement components also carry the same VIN number, which is not you VIN number, but that of the donor car.
.... and take out the old VIN # ??
