Wanted Outer sill
Murrayrichard
I’m sure I’m teaching granny to suck eggs but have a look at these images of one of my outer sills. What amazes me is the difference between the inner and outer surfaces. The outer surface appears to be reasonable – not perfect but OK. The the same area on the inside is dreadful! Without taking the sill off, you would never know of the ravishes of tin worm. If you are new to the Z3 I would suggest you strip off your outer sills and have a good look! My inner sill on the nearside will require welding but I’m told by MP Customs near Bude that I have caught the rust in good time. The outer sills should be sorted with the help from Fender2004 who can contact me via 01409 2 4 17 1 9.
I’m sure I’m teaching granny to suck eggs but have a look at these images of one of my outer sills. What amazes me is the difference between the inner and outer surfaces. The outer surface appears to be reasonable – not perfect but OK. The the same area on the inside is dreadful! Without taking the sill off, you would never know of the ravishes of tin worm. If you are new to the Z3 I would suggest you strip off your outer sills and have a good look! My inner sill on the nearside will require welding but I’m told by MP Customs near Bude that I have caught the rust in good time. The outer sills should be sorted with the help from Fender2004 who can contact me via *************
It’s not a good idea to post personal info on an open forum, better to send it through a pm.
Murrayrichard
Thank you Tony, I am aware. I am having difficulties accessing my PM's. Hence my msg. It will not happen again.
RB99
Hi, I'm looking for n/s and o/s metal outer sills ideally in silver for a 2002 Z3. Does anyone have any for sale or know where I can buy new ones?
You can still buy new from BMW.
RB2
Inverurie, Aberdeenshire
Bogo
I've just had a quote for non-wide arch ones from bmw £316 delivered for both sides pretty reasonable as ive seen 2nd hand ones with light rust for a £100 plus delivery each
RB99
Thanks RB2 and also t-tony for quick replies
