I have an OBC fitted to my Zed, but it doesn't work. I wondered if anybody has had experience of how to remove and repair them. Checked the fuses and they're OK, but other than that, I haven't got a clue!
Yep, I have seen this reported before.Hi could it just be the bulb that lights the display ?.![]()
Yep, The enitre console needs to be removed unless you have double jointed, double jointed wrists, the OBC is fixed to the back of the facia plate with two screws, a bit of a pig of a job if I'm being honest. The OBC can be replaced with a second hand unit without any hassle once removed, as you have the wooden facia kit installed the faceplate of the original OBC can be retained if you do have to replace the unit.The whole unit comes out forward had to replace mine when i brought the Zed as it on.lt showed a ppp error that would not clear. I think there is 1 maybe two fuses that feed it.
Did that lot used to be a car Gaz?You end up with sooo many bits
Parts of 2 different ones... I was starting to sweat a bit at that stage, soo many screws and clips.Did that lot used to be a car Gaz?
I think I may just stick a piece of paper on the front with some numbers on. Probably be more accurate!You end up with sooo many bits![]()
That's why mechanic's always have boxes of " Get you out the crap" bits and bobs. Bet @Lee has some?soo many screws and clips.
How's that done? Not sure mines massively out but interested in the know how ?You can actually recalibrate these OBC on the zed so that they are very close to your actual mpg.
