Oil change for newbie
Pendle996
Hi all. New to all this and I am after some recommendations for an oil change. It’s a minefield of over information! Just bought a 99 2.0 litre six. And always I like to get the oil changed straight away. Was thinking I’ll take it kwik fit, but not sure I can trust them. Then thought I’ll do it myself, but as yet don’t know my ass from a sump plug yet. My question is if you were off to Halfords what oil should I pick up, or order maybe thru Opie oils.,I like to put the oil in myself and not sure I can trust k fit. Is the oil change a pita?
SV8Predator
Z4 E89 2.0 Atacama Yellow / Z3 3.0 Topaz Blue
Just use KwikFit — they always treat me very well here in Banbury. It seems "clever" and "funny" to knock KwikFit, especially by people that have never used them.
If you do decide to buy your oil from Opie, you just put the make & model in and they will advise the correct oil.
Pendle996
Thanks. I wasn’t knocking them, and I know they have to put the right spec oil in. 👍
If you're anywhere close to Lincoln you can come and do it at my place. ZedShed (Midlands).
ps. Order from Opie Oils, oil and filter, they'll see you right.
John_B
Derbyshire, UK
Z3 2.8 pre-facelift (Izzy)
I changed my oil for the first time last weekend. Genuinely annoyed with myself for not having had a go sooner. Total piece of cake!
It was a little bit more expensive as I needed to get an oil pan and oil filter socket too, but for all future changes now it will just be the oil & filters
Pendle996
Yeah was thinking about doing it myself, but experience has taught me that summat usually goes wrong. Any particular tips and how difficult is it?
Pendle996
Thanks opposite side of the country👍
John_B
Derbyshire, UK
Same! lol That's actually one of the main reasons behind me buying the Z3.
I'm probably not the best person to give advice after only just popping my oily cherry. But honestly, it's really easy and pretty quick, even for a first timer!
I followed this guide: https://www.pelicanparts.com/BMW/te..._Engine_Oil/54-BASICS-Changing_Engine_Oil.htm
Although I am sure there are tons of other articles and videos stepping through the process
Pendle996
Thanks. I like the idea of doing it myself so will think about it today and look underneath. Just tell me what you put in it as it’s hard work cutting through all the specs. Regards👍
Pendle996
Also how much does the 2.0 litre flat 6 hold with oil and filter change? 6.5 litres?
John_B
Derbyshire, UK
Check the manual for the correct capacity and spec. Mine is the 4-pot.
Good luck!
Pendle996
Thanks. Trying to weigh up if it’s worth buying all the tools. Gave all my tools up when I left GB. Now I’m back I need to buy again. That’s why I thought Kwik fit. Must say people on here are super helpful it’s much appreciated. No such thing as a dumb question I guess👍
Peter1450
Bristol
Z3 3.0
Do it yourself just for peace of mind! The great thing about the Z3 is everythings accessible ie oil filter up top next to steering fluid so the only bit underneath is the drain plug.
Pendle996
You guys are making me do it then! I’ll give it a go
So done it was easy, pleased had to jack it up. So moved onto taking the wheels off, jacked it up, got bolts out. Could I get the wheel off, no way! Hit it with a dead blow hammer, nothing.
Any ideas you good people?
John_B
Derbyshire, UK
I had the same thing mate, all 4 wheels siezed solid. sprayed WD-40 into the bolt holes and through the spokes, aiming around the edge between the wheel and hub. Left it overnight and the next morning they all popped off with a swift hammer blow
Pendle996
Cheers, if I get them off I’ll smear mating surfaces with a bit of copperslip
Devon Z
Brixham, Devon
99 2.0 Individual
Bit academic now but I replace the two little rubber O rings on the oil filter cap spigot every couple of years or so, doing oil service/Mot next month🤞
the Nefyn cat
2.2i Sport
No, quite definitely no. The mating surfaces are there for a reason, to carry the weight of the car, all the driving/braking/cornering loads, and to locate the wheel in the first place. If you look at the hub you'll probably see a build-up of corrosion aroound the central spigot, take a stiff wire brush to it and the matching part of the wheel, and just leave it clean. So long as the wheels are taken of off fairly regularly for normal servicing they should be Ok. Putting copperslip or something similar reduces the friction between the mounting faces and can (not always) result in an unscheduled catastrophic separation, better to just keep things clean.
Oddly Godly
dunstable
z3 2.8
I use the halfords own brand they recommend for my 2.8. Many different makes can be used but the main thing is to change the oil every 5 to six thousand miles as recommend and change the filter.
