Still covid positive…. And if that wasn’t bad enough!
I heard a bang in the kitchen and found water draining out from the boiler….. a bolt that holds the inlet manifold to the heat exchanger had sheared off. Moved the microwave which was drenched, and got the washing up bowl to catch the water….. so replaced with a bucket. Into the loft and turned the feed to the header tank off….. then a hose onto the boiler drain…. Out through the kitchen window and drained it down into a gulley outside. The only ingenious bit was to use a mic stand to support the hose across the kitchen. Probably thd best use its ever had
Cleaned up the mess and dried ouf the microwave ….. and had a cup of tea!!!!
Decision was easy…. New boiler!!! Cant get a heat exchanger for it ( being 27 years old) snd even if I took the whole thing apart andgot thd broken stud out …. Cant get any of the sealing rings or gaskets
So spent the rest of the morning draining down the whole system. I was going to do a full system clean anyway….. but hadn’t banked on a new boiler as well.
Cant get anyone in as still covid positive, so may as well start getting all the rads off and get them outside to power wash them .
Will check it all now and replace anything that needs doing …..
Just need to find a boiler…. Glowworm, Potterton and Baxi all seem to do a like for like replacement…. But dont know which manufacturer is best …
The old one was a Halstead, but they became part of Ideal I think.
oh well ….Anyone want a Z3 kit car? At this rate I’ll never get it done
