It's some hardware that goes under the front of the seat to increase the angle making them more comfortableWhat is a seat riser kit please?
Its a pair of spacers that goes under the front rails where the seat mounts are, lifts about 20 mm to change the rake of the seat and give you support under the knees, I made my own and it makes a big difference, I believe @t-tony has some for saleWhat is a seat riser kit please?
I went for 30mm, it felt too high at first but I soon got used to it, it pins you back in your seat a bit more,I will try this, has to be worth a go. Thanks folks.![]()
I made them as I can mig weld but @t-tony makes and sells them I believe,Where did you purchase them from please?
