Now why is that?
Simon Blythe
South Birmingham
Why does the project car that I purchased feel as though I sit lower, the car is more planted and generally just very different? The car is standard, I thought it was lowered but now I'm not convinced and everything else is stock.
It's quite odd the difference in feel between the two cars!
I know M seats are marginally higher. Might be it?
Neither of the cars look lowered as said it could just be the seats and driving position.
Agree with the above. It certainly is not lowered so can only be the seats as that looks to be the only thing different
Standard seats are different in fit and feel its more likely the answer.
Have you measured the height to the wheel arches from the ground on both cars to see if there is any difference in ride height?
Have you entered the chassis numbers of both cars into the " How to find the options specified with your Z roadster" VIN de coder to see if either had Sport Suspension as standard?
I would go with "the overall diameter of the wheels with the 18" fitted is slightly bigger than the 17" ones...?"
How does it feel from the passenger side! Could be the standards are sagging a bit from use by a heavier owner in its before life?? JIM
Like you, I have two zeds, both made in the same year, same engine, almost same options and the vin numbers are almost consecutive, bloke at bmw asked whether I'd bought the two cars together...
Anyway, despite all of this the cars feel vastly different. Like you my project car feels like it's handles better. I think that the lives the cars will have had play a part in this. Of course like others have said, the seat and the wheels could also be the case.
The difference could well be difference between knackered and totally knackered bushes and shocks. Makes a massive difference. These cars can handle like a TVR (in a bad way) when all that is worn and feel totally different when fresh.
