Heatheross
- Joined
- Jan 14, 2021
- Points
- 3
Hello Everyone! I am a brand new member, and I need some help diagnosing an issue with my motor; I do not want to have the same problem again, so your input is greatly appreciated! I have a '99, Z3, 2.5L, Auto. The other morning, my motor would not start; when I had turned the key, it had only made a 'whining' sound; NO clicking, so it had not been the starter, and it is not the battery The spark plugs have about 6K miles on them. My mechanic had determined that everything under the hood is working properly. But, when he had pulled out the spark plugs and coils, he had found that EACH CYLINDER had been COMPLETELY DRAINED OF OIL! And, there had been ABSOLUTELY NO COMPRESSION! So, he had poured oil into each cylinder, let the car sit overnight, and it had started the next morning.
So, my questions are:
1. Why had all of the oil leaked out of the cylinders?
2. Why had there been no compression?
3. What can I do to ensure this does not happen again???
4. Do I need new rings? I beg of you, PLEASE DO NOT TELL ME THAT I NEED NEW RINGS, BECAUSE IF YOU DO, I WILL SHOOT MYSELF BECAUSE I CANNOT AFFORD SUCH A REPAIR! Okay, Okay..., back to my other reality; if I DO need new rings, please tell me so I KNOW HOW TO BEST PROCEED. But, if you do tell me this, I swear I am going to shoot myself. Even though I am not.
Okay, thank you very, very much for all of your help!!! ~Heather
