Newbie with z3
Ianmc
New Forest
Z3 (M44)
Welcome, what sort of problems are you having? Someone may be able to help.:thumbsup:
Dave Mckee
Lumpy tickover, car runs then looses power, starts but won't rev up, no faults in the ecu, put a new disa valve on, battery going flat now, going to change battery, I think the disa has cured the running issue but getting fed up with the aa man bringing it home, car only has 54k on it with fish, noticed the engine management light doesn't
Keet
Mansfield
E89 20i M Sport
Dave Mckee
Should say engine management light doesn't come on when ignition is turned on??
Maybole , South Ayrshire
Hi and welcome from me in Scotland :welcome:.
Bulb maybe blew or worse removed to hide light on.
Slam
North Yorkshire
Zedless. Mini GP 1379
Hi and welcome from London
Shelly
Norfolk
Z4 2.0 20i M Sport sDrive
:welcome: Hi and welcome to ZroadSter :coolsteer)
spurs fan in a coupe
Indeed, welcome Dave, I break a few z3s, mainly 1.9, in Woking, Surrey
All sorts of reasons for battery drain, from broken boot loom wiring to knackered alternator, poor connections etc.
Good luck- pop questions up on a fresh thread per problem and people on here will help you get the zed roadworthy
Dave Mckee
If bulb removed ecu would still store faults but no fault codes, not sure on power drain, going to change battery just in case it has a dead cell, will go from there, cheers
Jack Ratt
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
Hello and welcome to the forum. Common faults with these cars will be deteriorating rubbers on the intake, cam and crank sensors. All easy fixes though. What kind of diagnostic tool do you have?
Dave Mckee
Took it to a mates garage, not sure but probably auto boss?? I assume intake rubbers you mean in the disa
What Garry is referring to are the big rubber manifold connectors about 4" Dia. from the air filter to the throttle body to the manifold. A way to trace these leaks is to spray them with Carb. cleaner or even Clutch/Brake cleaner while the engine is running. Listen for increase in revs.
mwpe
Camberley
Hi and welcome from Surrey, if it only has 54k miles on it it probably needs using. :welcome:
