Decided to try the wheels I got from mrscalex a while back. I am planning to fully refurb them but curiosity was killing me... What do you guys think? My first impression is that the back is sitting quite high... Do I need lowering springs ?
Front & back I would say.Do I need lowering springs ?
It was only a test fit and the 16s are now back on. However I didn't take into account that the suspension has to settle after being jacked up. Thank you for the advice.You need to drive it around the block a few times to settle the suspension again. If these wheels are the same size as previous the gap will be the same. If you've replaced 16" wheels with 17" the gap should be 1/2" less than previous
Surely the 17s will have lower profile tyres than the 16s? Otherwise the gearing and speedo are going to be out. Definitely went lower profile for the 19s, down to 30 on the rears. And lowering the car is always good.You need to drive it around the block a few times to settle the suspension again. If these wheels are the same size as previous the gap will be the same. If you've replaced 16" wheels with 17" the gap should be 1/2" less than previous
