New member
From Stockholm, Sweden. I have a BMW Z3 1,9 Cab from 1998. It is in very good condition, except for the electrical seats that don't work.
This is the main reason I found this site, I would like to fix the seats this year and I hope I will find some DIY guide to help me.
The reason I bought the Z3 is that I think it is a truly beautiful car. I enjoy driving it as well as just looking at it.
Thank you all. Yes, I hope that thread can help me. I will have a look at it when the temperature is more pleasant. I don't have a garage any longer :(
Mazza
Bognor Regis
Hi and welcome from Bognor Regis.
If both seats are not working it could be something simple like a fuse. And easy to check.
F19 for drivers side and F5 for passenger side
Jack Ratt
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
Hello and welcome to the forum and good luck with your repair
Ianmc
New Forest
Z3 (M44)
Very much like the green/green. Can't think why!:)
Shelly
Norfolk
Z4 2.0 20i M Sport sDrive
:welcome: Hi and welcome from me too :coolsteer)
:welcome:
Slam
North Yorkshire
Zedless. Mini GP 1379
Hi and welcome from London
Jjim
Mansfield
1.9 Roadster
Hi welcome from Mansfield.
I’ve repaired quite a few seats. Need to get the seats out to investigate what the problem could be.
You will need to move the seats back and forward to remove the bolts. If the motors don’t work. I found that you need to unscrew the front motor from the frame to get to the spindles. I then put the spindles in a drill and this allowed me to then move the seat forward each side at a time. It does take a while, as you have to do each side an inch at a time, but it works.
If the motors make a quiet click when you press the button on the seat to move them. You know that power is getting to the motor and the motors might be stuck.
Hi Mattias and welcome from me too near Lincoln UK. When does "Spring" arrive in Stockholm ? Hope you find the info you need, most things can be repaired by asking on here. Good luck and continue enjoying your Z3.:)
Mazza
Bognor Regis
Just to add to Jjim thread,
If you use one drill to move seats you need to forward and reverse the drill as you go side to side. When I did mine I used two drills, one on forward, the other on reverse and it is a lot quicker.
Also, I was lucky enough to be able to disconnect the motor connector under the seat before removing anything, and was able to check it with a meter and found there was no continuity through the coil, so I knew it was duff.
