Great stuff I love my mini ! Mine is the R53 though jcw GP little rocket.
Really useful so far, particularly with no temperature gauge in the car and the alternator issue it had. Usually have coolant temp, boost psi and battery voltage on the main screen but there’s another 70 odd values it will display.How do you find the ultra gauge is it useful was thinking of getting one for mine.
Roll bead at the end. You can do it with a tool usually available at tuning shops, or weld a bead three cm from the end. Had a Lancia in the past and all hoses popped out until I had the ends welded all around.This is becoming a progress thread on it's own now! Mainly enjoying trouble free motoring but always improvements to be made...
First off, silicone hoses...
This has worked off about 4 times now, it's the cold air feed to the turbo, and this silicon pipe is a common change on the N14 engines. However because the inlet is smooth the silicone doesn't have anything to bite in to and works it's way off.
So, I've cleaned it all up and tried to rough the surface up on both the inlet and the inside of the silicone pipe - then double clamped it... You can see where the clamping force is mushrooming the end of the pipe already. Will see how it goes, but if anyone has any suggestions for this kind of situation let me know.
Is the "OCD" plate by designCoilovers and rollbars for Christmas please Santa
I prefer the term "ironic"Is the "OCD" plate by design![]()
That's Spurs fan, and he has his own tales to tell from the dayDid you catch that old silver zed in front
It'll end in tears, you mark my words.Coilovers and rollbars for Christmas please Santa![]()
There is a bit of life left in it, but with my driving it’ll need to come out by the end of the year anywayNot sure you got your moneys worth out of that clutch,
