Thanks.
Love the colour of your car what is it called?
Thanks.
Hey I am in Romford!Hi and welcome from London
I love that Yellow... i though only available on the Z3MHi and welcome from me in Scotland![]()
Thanks...Welcome Dave
Think I paid around £20 for a poly bush off ebay. Quite an easy job to do as long as you've got a trolley jack. Only 30 minutes labour for a garage to do it so maybe £50 ish.You. Are spot on regarding the bush in the middle... just identified it yesterday... any idea how much parts and labour should be?
Will check spot welds and update pics...
With cooling system will address at the first sign of overheating
Thanks...Hello and welcome from Truro. Good luck with the project.
My car is currently laid up waiting for me to get my arse into gear to change the head gasket.
from me
Really appreciate it...Just checked my diff bush was a powerflex.
It's a special colour from the 'Individual range. It's called Aegean Blue. You won't see many aboutThanks.
Yes mate that's the boy.Really appreciate it...
I am not a mechanic but is this the product?
https://www.ebay.co.uk/itm/400378624572
good luck with the project Thanks.I love that Yellow... i though only available on the Z3M
"Aquasteel" is a rust converter that you can use on the rusted parts.The car doesn't overheat so I will hold on cooling.. and the car starts ok so will hold on the oil and plugs... the car clearly was parked up for sometime and a fair bit of rust but a local mechanic said there is a special chemical for underbelly for rust... will keep you posted...
That head gasket job might be easier and quicker if you you used your hands!.....Hello and welcome from Truro. Good luck with the project.
Well Bonzo old boy, most of the time I don't know whether I'm on my arse or my elbowThat head gasket job might be easier and quicker if you you used your hands!.....
Bonzo
What Ho Jackers! I had the same problem a while back, so I went to see the M.O. chappie. Said too much Port was muddling the old grey matter, so I cut down a bit on that . Seemed to do the trick for a while, but I got a taste for some old Brandy that the Club keep, so I'll have to see how it goes. Long as the memsahib doesn't find out I should be okay..... Purely medicinal don't cha know!Well Bonzo old boy, most of the time I don't know whether I'm on my arse or my elbow![]()
