Rebody My 250 California build
Jezza
Yup. Single is all I have. Just 3m wide. It's quite high so just added a mezzanine floor to put lots of stuff out of the way so that I can actually open the doors a bit. Also makes the ceiling lower so hopefully warms up a bit come winter. Got some lighting in there but not enough. Planning on getting a lift but can't decide which. Don't plan on working under the car much but just lifting to make it more comfortable working along side the car without bending over all the time.
A lift is well worth the investment. I got mine at the end of my build but it's been brilliant ever since.
TBH that does absolutely nothing for me. It's 'California' or nothing in this house!
That's how I feel about the Z4 E86. It's not a cabrio . . . . .
jaguartvr
If you don't want the expense of a lift you could use air bag lifts. I have a gravel drive so it's a pain dragging trolly jacks around. With the air bag lift just throw it under the car and attach it to your compressor. You can get them for around £70.
Best to buy a pair.
Duncodin
Pontrhydyrun - in Crow Valley
M44 FrankenZed
Another Z based car was there the same day. I remember speaking to the owner. Might be Z3M based.View attachment 281377
632 YUJ is a Tribute. See what this guy haa done to the door window. Looks like it has a frame around the door window and slidey windows installed. Does that window frame come from tribute or did owner make/source them?
Pingu
They were the original solution, but it wasn't very successful. The best solution is the electric window solution from Greenbanks. It's very expensive, but most things on these cars are very expensive. The production numbers are in single figures, so there is no economy of scale.
The sliding windows are perspex and they scratch and glaze very easily.
Jezza
What's the manufacturer and part number?
Is that lifting on the sills? Jacking points?
How heavy is it?
Platinum 3000
It's lifting under the jacking points. Heavy but can be moved with the supplied tool.
Pond
Spaldingski, Lincs
Z3 project
So got the donor car. After a day and a half going through it, it does seem a really good one. No rust anywhere. A good service history too. Obviously been garaged all it's life. I will be getting a new roof at some stage, but the mechanicals look really solid. Going to get the Vanos serviced, oil changed and brake fluid changed then we are ready to get cracking!
jaguartvr
Looks like a great donor, being a later 30 it will all be satin black under the bonnet meaning you can paint it any colour you want.
Take some photos of it now before you forget for the DVLA, front ,back and sides showing the number plate also the stamped VIN number, this is on the panel in front of the windscreen directly behind the engine. Peel down the sound deadening and it will be revealed. The number visible in the windscreen is only a sticker and the new bodywork will cover it.
If you are servicing it, allow for a set of EBC green stuff brake pads, these produce less dust and contain no metallic particles, this makes the wire wheels much easier to keep clean and stops rust forming.
Certain parts will sell quickly and for good money, sills and door mirrors, other parts such as the boot lid are hard to sell. I sold a couple as a body swap. buyers drove down and we swapped all of the body panels in a day, they left their old panels so you still have the boot hinges. boot lock, bonnet pins etc. I think I sold mine for about £1500 each but that included fitting it all with the help of the buyer. Saying that you should get £500 for the mirrors and sills and a lot less work. Staggered alloys are always a popular second hand item.
The only downside to your donor is that it doesn't have the alloy windscreen surround which makes the build much easier. You can still buy them from BMW and they are not that expensive, but you need to remove the windscreen to fit them. Worth having in stock just in case you get a chipped windscreen and have to have it replaced!
Pond
Spaldingski, Lincs
Z3 project
It's all blue under the bonnet but I still want a red car!
jaguartvr
Must be an early 3.0, the later cars were black under the bonnet.
Easier to paint it satin black and get a good finish with a spray can or brush than trying to get a good finish in body colour.
Not much of it is visible anyway.
Jezza
Mine was grey but I've painted it red. Careful masking and used primer followed by 3 coats of spray-can top coat in the same colour as my bodywork will be. Well worth the effort and makes a huge difference. You'd be surprised at how much is visible after the body swap.
Pond
Spaldingski, Lincs
Z3 project
First update:
Body panels almost stripped. Interior half stripped (and wiring labelled).
There have been a few hurdles so far, which are not all rectified yet. Water has been getting in to the interior (A pillars), so the carpet foams are all sodden (and I mean sodden). This has fried the two DSC sensors on the pax floor (even though it passed an MOT with no advisories a few days before I got it :mad:. Someone got a dodgy MOT done, as, aswell as the DSC the front discs are below minimum thickness and there is a big chunk out of one of the tyres).
It looks like the big seal on the windscreen/ roof is blocked all down the A pillar, so may need a new seal. There has been water getting into the boot from the aerial grommet as this was split. Sorted and I won't need the external aerial but it has rusted the main aerial bracket so there is no radio reception. I can sort this easily, though.
The car had been stored previously for quite a while, so it has become resident to many, many families of mice. I have got three bin bags' full of leaves, compost and cob nut husks from various places throughout the car. The inner sills were both full of leaves and woodland produce. even the alternator vent duct was clogged with leaves! Luckily the rodents haven't chewed through any wiring, or anything required to be kept.
Vanos has now been rebuilt, along with brake fluid, oil change, new filters and plugs. The engine purrs like a kitten now.
On the plus side there is no rot or corrosion anywhere, the body, tub and chassis are in exceptional condition for a near 23 year old car. Just about to take the plunge with the expensive bits, so wish me luck!
jaguartvr
This is what I use as a replacement aerial, cheap as chips and works well. Just screw the wire into the old base and mount on the inner rear wing shelf. Great reception.
DaveP
Reading
Z3 2.2 Kobra rebody (see pic)
Great update and interesting regarding the 'lenient' MOT.
A radio ? Who needs a radio ;)
Dxbolton
New Forest
2.8 auto
I hadn’t realised the small wire next to the aerial base was the earth for the radio! After refitting this all the radio station suddenly stated to work
DaveP
Reading
It's for drowning the wife out, "stupid boy" :whistle:
not having a wind break helps a lot. i also have a bluetooth speaker strapped to the trans tunnel helps too :)
Jezza
You need to keep both rear wings as you will have to trim them and use them to mount the rear grp bodywork. Don't get rid of them!
