My 21yr old topless model 2.2
AntStark
Hampshire
2002 3.0 Sport
3 year ownership update
Start mileage 97,527 Feb 2022
1yr mileage 103,927 Feb 2023
2yr mileage 110,202 Feb 2024
3yr mileage 116,650 Feb 2025
6448 miles this year
30 fill ups
Ave consumption for the year 27.2mpg
3,5l of top up oil used this year
Total costs for the year;
Parts, accessories, repairs and maintenance: £2155
Insurance and tax: £785
Fuel: £1800
Running Cost: 74p per mile
Another fun year of Z ownership. Undoubtedly the highlight was a weekend trip to Wales in April 2024. I was pleasantly surprised at how well she performed. I was also able to spend some time giving my son driving lessons in it.
I did have a few understeery moments on the Wales trip and although handling was fine over the summer, more recently she’s been tramlining quite badly, so a new set of front tyres is on the menu. They’re still hardly worn, but they’re 10 yrs old, so I’m not surprised.
I might also get the lollipop bushes done this year and I’m thinking about having the wheels refurbished. I clearly haven’t been cleaning off salt regularly enough and there’s corrosion setting in.
Another worry is the roof. The trim and stitching around the back window is starting to look a bit suspect, but maybe that can wait another year.
Your own zroadster calendar.. done
Jam03
Surrey
2.2i
I only ever take mileage into account when looking at 'running costs', so thanks for that.
My wife does around 9,000 miles per year now just commuting. I keep telling her that the cost equates to 20% of her wages, but she doesn't believe me.
I am going to use your figures to show her it's actually more like 30%. Just to get there and back! o_O
Don’t blame me for the fallout!
I also keep track of the total cost per mile since I bought the car in the event I wanted to sell, but that figure is very sensitive to how much you could sell for, so I only look at the running costs per mile now. Now that it’s pretty stable, I think I might lose interest😀
In any event, I can see how Z3’s and other relatively cheap but interesting cars end up being scrapped after being owned by people who can’t really afford the maintenance.
Jam03
Surrey
2.2i
I’ve noticed a deterioration in my roof recently and last week a small crack appeared in the window. The stitching is also pulling away on one side of the window.
I briefly considered just getting a new window, but given the overall condition of the roof, it didn’t seem wise. Jack Smith’s booked for May.
AntStark
Hampshire
2002 3.0 Sport
What’s the going rate on a roof at Jacks now @Jam03 . Mine is literally in shreds .. not that I use the car when it’s going to be wet but it would be nice if it was watertight.
Jam03
Surrey
2.2i
Finally got round to replacing the front tyres with Pilot Sport 5’s to match the rears I got last summer. Booked in for front only alignment as well, which was out and couldn’t be adjusted on one side because the nuts were sized on and ATS don’t apply heat. Not ideal, but fe
The front tyres I had on (Toyo Proxes) have done 20k miles since I have had them. They came fitted to the rims I bought just after I got the car just over 3yrs ago and still had a healthy amount of tread despite being 10yrs old.
AntStark
Hampshire
2002 3.0 Sport
Are you going to find a proper garage to do your alignment? ..no point trashing that nice new rubber. 10 year old tyres will be shot however much tread there is
Jam03
Surrey
2.2i
Needs a service next month, so will address then. It’s wasn’t that far out, but annoying.
AntStark
Hampshire
2002 3.0 Sport
Be worth getting new inner and outer track rods whilst they are doing it..they are cheap and make a big difference to the steering feel
Jam03
Surrey
2.2i
4th oil service under my ownership done today at BMS Surrey. Also a bit of a pre MOT inspection. Definitely think I’m helping to keep the petrochemical industry afloat, but discussed a few jobs that should address some minor oils leaks.
AntStark
Hampshire
2002 3.0 Sport
Getting the piston rings changed ? Does it leak or just use oil ?
Jam03
Surrey
2.2i
Oil filter gasket, VANOS feed pipe and rocker cover gasket have small leaks. I think it also uses oil, but not worried about that.
AntStark
Hampshire
2002 3.0 Sport
Quick and relatively cheap things to do 👍
Jam03
Surrey
2.2i
Another MOT done today. Only some rusty brake pipes as advisories. Initially failed for headlamp aim and indicator bulbs not orange enough! Annoyed about that, but the suspension and oil leak advisories from last year didn’t come up again despite not doing anything about them. Mind you, I did clean up the most obviously visible oil leaks.
A pass is a pass, another 12 monts of smiles ahead:thumbsup:
Jam03
Surrey
2.2i
Finally got around to changing the bond cable between the bonnet and the body that looked a bit untidy. The cable was wrapped in insulation tape that was hiding some damage. Found a cable in Halfords that was almost identical and very cheap.
AntStark
Hampshire
2002 3.0 Sport
Never noticed that before ..does your car go faster now ? 😉
