Mot
Hammers
Just past the mot . But is a bit rough on start up from cold any clues ? Thanks :coolsteer)
Aceman
Moderator
Wakefield
///M Roadster
Well done on passing your MOT always s good feeling.
With regard to your rough idling could be a number of thingd from a split intake hose to cam sensors it is hard to tell with such a vague description but it is not that uncommon a problem so if you give us a bit more info I am sure we can all help.
Hammers
It's been on a computer and it says it's a electrical fault there is a small split on a hose I am getting that sorted it only does it for a few minutes from start up and then is fine the mass airflow sensor has been changed for a new one was going to change the lamba sensor but don't want to keep wasting money if that is ok any ideas many thanks its not indicating cam shaft sensor either
Aceman
Moderator
Wakefield
///M Roadster
Well the spli hose certainly wont help, what code did it come up with when you had it hooked up to the computer?
Get the hose fixed first then if it is still misbehaving we can investigate further.
Hammers
Ok will do thanks for your help . Can't remember the code but have to go back to the garage next week will let you know the code next week :coolsteer)
billz
Langley Mill
Our Zed is going in tomorrow as it has just started cutting out when at junctions.
bill
billz
Langley Mill
Well just had car checked and £118 lighter. Had to have exhaust cam sensor changed, luckily Dealer had one on the shelf £88.
bill
Hammers
Hi guys tha code are 062 3e misfiring sum relevant to exhaust gas 051 33 misfire cylinder 2 relevant to exhaust gas and 052 34 misfire cylinder 3 relivent to exhaust gas :coolsteer)
Macca
Wisbech St. Mary
2.5l Msport
It seems such a long time ago you could clean the points and rotor and it would start lol... :D
Macca
Wisbech St. Mary
2.5l Msport
gookah said:
Not after I fitted my 'Sparkrite' electronic ignition.
I also fitted the Raydyot heated rear window too, :-bd
Now there's a man from my era. Sparkrite electronic ignition, it's the future..... :D
2.2 & 3.0 Sport
Me also - I remember building my Sparkrite from a kit :)
