Mot question
brilie
doncaster
2.8 roadster
Sorry not zed related but can I ask our two resident mot gurus a question?
Tony or Steve please help and answer me this?
My daughter has a Honda Civic but recently clipped the near side wing mirror
Leaving the glass cracked.The mirror is still fully functional moves in all directions
But is cracked.
The mot is due shortly leaving the question ...will it pass or does this mean a fail.
A full wing mirror is quite expensive and coming up a Christmas and all do we need
To replace it?
Thanks in anticipation
Brian
Brian H
Killin
E36/7 3.0i - E85 Z4///M
Don’t know the answer brian but being a tad superstitious you need to remove the broken mirror and bury it under an oak tree!!!
@t-tony @Stevo7682 ^^^^
Grumps
Forest Town, Mansfield
Z4 e85 2.5i
I suspect it's advisory Bri bit Tony or Steve will be along to tell me I'm wrong lol.
As long as the interior mirror is intact and fully functional, along with the Offside door mirror then the nearside mirror does not have to be tested.
A vehicle has to have1, the offside mirror and 2, either the interior mirror OR the nearside mirror.
https://www.mot-testing.service.gov.uk/documents/manuals/class3457/Section-3-Visibility.html
This section in the manual used to be called "Driver's View" now for some reason it is called "Visibility" ????
Brian H
Killin
Every day is a school day :thumbsup:
@brilie , a cheap fix would be a "stick-on" replacement glass from an Auto parts supplier. OR eBay. Probably only around £12 or so mate.
brilie
doncaster
2.8 roadster
Thanks Tony,
It’s really handy to know people in the know!
Much appreciated
Brian
Thanks Tony,
Much appreciated
Brian
You're more than welcome mate, any time.
Paul Rice
Doncaster
Z4 2.5 E89 23
Mirror glasses are available on e bay for the civic without rip off honda prices
Since Tony got there 1st I will just add a little bit .
If the glass is damaged but still provides substantially a view to the rear it's pass and advise but as said I would probably get a replacement stick on mirror and stick it over the damaged one if the housing is all intact and you stick it on straight you'll barely notice the difference.
Shelly
Norfolk
Z4 2.0 20i M Sport sDrive
My offside mirror fell off :p
I stuck the new one on with sticky tabs and it's fine and you can't tell the difference :)
Grumps
Z4 e85 2.5i
So I'm right then @t-tony! :rolleyes:
brilie
doncaster
2.8 roadster
Thanks Steve,it’s great to know we have some experts (and grumps) on
The forum and its more reassuring when they come up with the same
Answer:thumbsup::thumbsup:
Thanks again all
Brian
No offence Dave=))
Redline
Nuneaton
E89 20i msport
Just one thing about sticking a mirror on. If they’re heated (most are) does the heat stand a chance of causing the glue to become soft and the mirror dropping off?
Contemplating using high temperature glue/sealant (previously used to replace the glass door on an oven) to replace a door mirror.
brilie
doncaster
2.8 roadster
I would hope if they sell a mirror to stick on something ,it would stick!!!
But in today’s world :wideyed::wideyed::wideyed::banghead:
Thanks for the thought
They are supplied with adhesive that is designed to do the job. Never had one come adrift. Did lose oan oruginal BMW one last winter though.
Redline
Nuneaton
E89 20i msport
My thoughts are cheap will mean cheap components. Can you see some Far East slave shop being worried about whether or not the glue will last beyond the day it’s first used?
Me neither....
If you use some decent 3M pads you’ve got a fighting chance. :thumbsup:
Never had one come off so that speaks volumes to me . . . . . .
At circa £12 certainly less expensive than a new mirror at anywhere near £120 upwards but for a piece of mirrored glass and a sheet of adhesive not particularly cheap.
Grumps
Z4 e85 2.5i
Thanks again all
Brian
No offence Dave=))
Offence taken Bri. :mad::D
There are a number of cars that you can buy an aftermarket replacement glass for not sure if civic one of them
