So you're testing a car and you see this, does it fail ?
Nasty. Tyre has 7mm of tread and very even wear though.
I only knew because a guy at work had this on his MOT check. He had a dangerous fail for imbalance, but an advisory for a nail in the tyrePass and advise no fail for nail in tyre![]()
You are right even though the tyre can't be fixed most nails and screws leak slowly if tyre holding air and no other fail criteria caused by it's presence ( for example it had went in at an angle then got pulled straight ripping the tyre and exposed cords ) then pass and advise.I only knew because a guy at work had this on his MOT check. He had a dangerous fail for imbalance, but an advisory for a nail in the tyre.
