So you're testing a car and you see this, does it fail ?
Nasty. Tyre has 7mm of tread and very even wear though.
I only knew because a guy at work had this on his MOT check. He had a dangerous fail for imbalance, but an advisory for a nail in the tyre.Pass and advise no fail for nail in tyre
You are right even though the tyre can't be fixed most nails and screws leak slowly if tyre holding air and no other fail criteria caused by it's presence ( for example it had went in at an angle then got pulled straight ripping the tyre and exposed cords ) then pass and advise.I only knew because a guy at work had this on his MOT check. He had a dangerous fail for imbalance, but an advisory for a nail in the tyre.
