On start up engine light on and running lumpy, mate of mine plugged it in and says misfire on cylinder 6, replaced coil and new plugs fitted, any ideas are welcome.
Thanks
Thanks
HiHave you had a reader on it, if so did it throw any codes up?
Agree with eddies comment. I would go one step further and take all the induction system off up to the inlet manifold. It's more likely to be a seal that's perished sucking in unmetered air causing the misfire.I'm no expert, but could be an injector issue. May also be worth looking at the air intake pipework (filter to throttle), it is prone to cracking and letting in unmetered air.
Hi,Hi
Yes it did, my mate did took a photo of the codes, it was some time ago but I'm sure he will still have them or I can get him to plug it in again an record the new codes and let you know, can't wait to get it up and running and start enjoying it.
