Mirror disassembly?
@mrscalex (and actually, *everyone else*) thanks as well for your input, and the thread related to cutting the axis side...
I'm /fairly/ sure I should be ok once the washer is cut, the two parts move a little bit, given enough persuasion. won't rotate, but they 'rock' a bit, so they are not entirely seized. Seriously that mirror assembly is both completely overbuilt AND fragile at the same time, hard to beat :)
Anyway, I'm glad I planned a bit longer than a few hours for that job ;-) Also had to repair the inside of the door card that has been 'pulled' bit too carelessly before, and superglue&clamp some of the leather trim.
Every cloud ;)
buze
Berks/Powys
2.8 Facelift
Well all ordered, as well as fresh cutting discs.
Did you guys also repaint the main part of the mirror, mine had picked a few scrapes and dents. I'm thinking of sanding down to a nice finish, then re-paint it over. Not entirely sure if it's colored plastic or if it has been painted...
mrscalex
Swindon & Swansea
The mirror cover?
Almost certainly painted. BMW supply it as an unpainted spare anyway.
I think it depends how good your spraying is. The mirror base is tucked away so is more forgiving if the finish isn't perfect.
The cover stands out much more.
buze
Berks/Powys
2.8 Facelift
Success! I used a variation of the cut, a bit sideway so I didn't even have to cut the base that much for the washer to break. Used the Persuader to remove it and everything fell apart as expected...
I I went ahead and sanded everything, including the plastic. Applied a couple of thin coats of etch primer, let it dry and applied a couple of coats of regular primer. That's all I can do today anyway as it started to rain.
I also applied some 'stone guard' spray paint to the aluminium chassis, bolt, and spring.
Tomorrow, color, then multiple coats of clear to seal the lot and reassembly, hopefully this week-end.
mrscalex
Swindon & Swansea
To remove starlocs I cut across 2 or 3 tangs on the inside. That way it doesn't cut the base. Not a big deal though.
