So near, yet so far.......
Well, it's all in. I still need to add three terminals to the engine ECU plug to power the compressor relay, take a signal from the AC switch and pressure switch but, with it all in, time for some R134a, eh?
It held a vacuum as it should and took 826g plus some oil like a champ. For now just to test it I could power the compressor straight from battery + and whilst it worked and blew cold air the compressor sounded bloody awful. Not just that but the power required pretty much stalled the engine and the smaller diameter AC pipe got very, very hot. That's some serious pressure and the best guesses all round point to the expansion valve. So, I have a new one on order. The AC was vacuumed out again and the saga continues.
I had a 318i E36 in this week for a head gasket and once it was all done, I powered the compressor from battery + to make sure it should still temporarily run without the pressure switch and it worked fine. I have a spare compressor as well so with fit that before a second regas.
