Bret Goodfellow
- Joined
- Mar 8, 2018
- Points
- 13
Thanks Pingu. I have ordered my kit. I did take the //M to the mechanic this morning, and he performed a compression test. All cylinders were above 150 psi. No air leak down was performed. The owner also is guaranteeing the motor for 10,000 miles. He also replaced the intake camshaft position sensor for free ($450 job). The owner does want to work with me, and I can tell he is freaked out about his mechanic and what he did. But still, even with all the owner has done, I'm still really concerned about my z3 //M Roadster. Geesh.Sorry - I didn't see the .
Either way, get an oil sample. Quick Google search = https://www.blackstone-labs.com/free-test-kits.php
$28 for piece of mind or $28 to use as evidence that you need a stripdown.
Most people know that most engine wear is caused in the first 10 seconds, so starting an engine without oil is a big no-no.
