Having the unit apart, I can see that the only area that looked iffy was the 2 terminals for the long pin, so they were resoldered. Fairly easy!
Off to test the car.
The light went out within 100 yards! Bingo! problems solved!
I went for a couple of miles run, no problems!
Returned home, turned off/on a half dozens times, light now goes out! Relax.
Or so I thought. Came back to the car 30 mins later, turned on ignition, light stays on.
Went for a mile run, didn't go out.
Stopped and checked connector, off/on, all ok.
But heading off, within 100 yards, light goes out! Returned home, off/on with ignition, light goes out. Hmm. Waite 30 mins, tried again, light stayed on.
Went for another run, light stayed on, but stopped, reset plug, within 100 yards again, light goes out!
Repeated above 2 more times. same results.
I don't know! SI batteries?
Can ABS units be swapped or do they need programming?
Thanks for everybodys help and reading!
