3/4Rear disk is because you don’t use it for half of the year![]()
This shows the angle of the two bolts. @AntStark and I had no luck attaching the M7 nuts as the fuel rail and electric rail are in the way. Going underneath is at the wrong angle. Are there any videos or instructions for removing the rails? Thanks RichardM7 11mm did seem an odd size to me at the time
Bmw's and their quirks
Luckily I have had good experiences so far of parts coming from Germany, being delivered in about 6-9 days
Is that £25 a nut!! Surely not!!
Good luck! Chris.
Thank youUndo the two 10mm bolts holding the fuel rail in place, you can tilt it over for better access. Or even lift it up slightly, just holding down the injectors on 0-rings.
Thank you
is that after prying off the long plastic electric bar that is clipped alongside?Undo the two 10mm bolts holding the fuel rail in place, you can tilt it over for better access. Or even lift it up slightly, just holding down the injectors on 0-rings.
I watched a video and thought that too. Not sure which 10mm bolts @Lee is referring to that hold the fuel rail on.I would try your best to leave the electrical bar on the fuel rail, because the clips that hold it on are an absolute nightmare, at least for me anyway
Good luck !
Chris.
Hi prying anything on a 26 year old car scares me somewhatFuel injector plugs are not bad to get off once you get used to them.
It literally takes brute force. Start at one end and pry the rail until the plug comes loose. Seams wrong at first but the plugs do just snap on and off. They don't break and the metal clip just expanded and comes off the injector.
Might be worth replacing the mssing nuts initially just to see if it makes any difference?
That's the power for the injectors and manifold sensor, Can either pop that off or leave
Would you take a close offer
[/QUOTE Yes. I can deliver it too
