Here's a graph showing the STEADY STATE air velocity through each of the screens.
I used this rig to make the measurements
All the possible leakage edges were sealed with Plasticine. The yellow thing is an anemometer. The cardboard tube has 82.5mm ID.
The orifice at the base is 38mm. This is the best size that I found that allows the manometer readings to be in the range of the inclined manometer that you can see at the top of the image.
I used my vacuum cleaner to "suck" at a given depression (measured on a manometer that is inclined at 8.75°) and read the associated air velocity on the anemometer. The graph above shows the average readings for the four screens that I tested.
In steady state conditions, Windy's screen and my newest hexagon screen were both better (higher air velocity at a given depression) than the OEM screen, but (unsurprisingly) were not as good as having no screen.
but, I also did an acceleration test (which is NOT steady state). IC engines are not steady state engines.
I switched on the vacuum and, using a 50fps GoPro, read the manometer as the depression moved along the tube. Below are the results of the test (converted into seconds)...
Excluding the potentially corrupted data (Open Test 1 (27cm) and Test 3 (25cm)), the times for the depression to go from 1cm to 25cm were (fastest-to-slowest)
Hex_08 = 1.77 seconds
OEM = 1.81 seconds
Windy = 1.84 seconds
Open = 1.87 seconds
from 1cm to 26cm:
Hex_08 = 1.89 seconds
OEM = 1.94 seconds
Windy = 2.00 seconds
Open = 2.01 seconds
from 1cm to 27cm:
Hex_08 = 2.09 seconds
OEM = 2.16 seconds
Windy = 2.25 seconds
Open = 2.27 seconds
In non-steady state conditions, my newest hexagon screen allowed air to accelerate through it faster than the other screens.
I've got more tests to do, including a full air filter test and a test with the screens on the car.
