- Joined
- Dec 8, 2011
- Points
- 145
I think that the main problem with this thread is that it is trying to target the wrong thing. It is targeting marginal gains when there is a much larger gain to be had by improving the airbox.
2cm H2O is a large amount of drag and should be quite easy to improve.
I can render a drawing for a 0.25mm nozzled printer (standard nozzle is 0.6mm), so I've splashed the cash (£2.99) on a 0.25mm printer nozzle.
I'll have to wait until later in the week to see if the printer is up to the job of making thinner-walled screens.
My MAF doesn't have a wire mesh.Hi, certainly very interesting shame you could not test with thinner side walls, did you remove the wire mesh from behind the front screen?
Andy
), or the most straightening using the least plastic.
