M52tu Manifold Swap
I used the existing injectors ,not sure if you can use them are they a higher flow rate?
I just pulled a whole intake manifold with disa, ccv and icv m54b30 from 2001 x5 3.0
I have a 2000 z3 2.8 m52tub28.
I know the gist swapping the manifold but i want to know if i could reuse fuel injectors, icv, fuel rails on my m52.
Things i read to swap.
Disa (bigger on m54)
Intake assembly
Adapter plate for my throttle body on m52tu
Should i get the fuel injectors on the x5 or reuse mine?
Also im deleting the ccv and fittibg oil catch can
This is my first and id be happy to do all the work and learn.
Thank you in advance!
I used the existing injectors my car went from 193- 211bhp no issues everything was bolt on all sensors the same.
As you say Disa and adapter required.
I rebuilt the disa valve to with a new flap and seals but if all looks good there is probably no need. Good luck
