Yes, s50b32 manifolds, s50b32 lambda sensors (very important as they are actually longer and if they are not in the true gas path they read incorrectly) or you need to grind of the insert lugs and re weld on nuts or short threaded lugs. Z3M twin cats, Z3M Roadster Rear Sebring back boxes. Race team re mapped ECU with their own chip. Larger injectors, E36 dual lambda wiring loom. Platinum plugs. All three turns/stages on the throttle body bored out to 67mm and 67mm butterfly, CDA carbon intake and filter (believe it or not it made a tiny bit more power than the Simota) 98-99ron.
I didn’t do the cams as they only give you 8-10bhp, they are difficult to source from the USA in good condition and Shrick ones are £1k but the main reason was that the torque is reduced down low and the power is all up the top and I felt this was more track focused and I use the car on the road.
Sorry I don’t have a build thread but I may be able to source the kit. It is a comprehensive and beautifully made kit, it’s not cheap (it’s £400) it’s not an eBay plate and some pipe plugs. It has very nice billet machined mounts and is very nicely worked out. The machining on the throttle body is superb.
I will likely sell the entire kit on one day as I have an e92 v8 plan.
