This all sounds very interesting and good luck to you.
I have a single mass semi track orientated clutch and light weight aluminum fly wheel waiting to go in mine.
With the electric steering what are you planing to go with? Something from a z4? If you are be careful and try and get the parts from a facelift car. As pre face lift cars can suffer from a sticky steering issue. My understanding its due to bushes binding in places once they get above a certain temp. It can probably be fixed. But i am going the other way back to hydraulic for feel and to get rid of the sticking problem.
Once i get around to changing mine over your welcome to have the bits. It will be the motor and rack only as i will be using the steering shaft. It might help work things out?
