Quinton
Hi m44 massive, i finally got round to reading codes on my z3 (1998 June) m44 1.9i after clocking up 100k. Ive recently replaced ICV which solved stalling/hard start when cold but have noticed some other minor issues when driving. The codes I am getting are (reoccurring after clearing)
p0340 Cam Shaft Sensor A Circuit Bank 1 or Single Sensor
p0130 O2 Sensor Circuit Bank 1 Sensor 1
p0135 O2 Sensor Heater Circuit Bank 1 Sensor 1
Q1 So my question is if I replace the Cam Shaft sensor with OEM part will this likely clear up the O2 Sensor codes? Or is there also a problem with the O2 sensor?
Q2 Is the O2 sensor on the m44 changeable by DIY home mechanic or should I use indy garage? Cam shaft sensor replacement looks straightforward.
Q3 Can I drive the car waiting on parts?
Thank you for any advice / experience. Ive read some threads which suggest the O2 codes are related but not specifically these codes. No EML light on, I haven't checked the bulb :\
