Loose handle
Romeo
UK
Z3 2.0
Hi guys,
My driver side door handle is on it's way out, do I need to replace the whole handle or can I just replace the knackered catch ?
Anybody has one for sale ?
Cheers
Romeo
UK
Z3 2.0
if you look carefully you can see that the catch that you pull to open the door has dropped, I need to pull harder to open the door now, everything else is good.
Yes the rubber gasket had it so will replace it too.
vintage42
if you look carefully you can see that the catch that you pull to open the door has dropped, I need to pull harder to open the door now, everything else is good...
I can't see that in the picture. Is the handle off the car with a brick wall behind it? You have taken the door panel off and the interior of the door is open?
I am not sure that having to pull harder is the fault of the catch or handle. It is such a simple part with little to bind or resist, as I remember it. Perhaps the problem is in what the handle pulls on.
vintage42
Not such a simple part, after all. I remember now, to change the rubber gasket, I just had to loose the handle and push it outward enough to slide the gasket down behind it. Didn't take it out.
