Loom of Doom
Dalek
Highworth, Wiltshire
Z3 2.2i Auto
Just wondering whether the phrase ‘Loom of Doom’ refers to a specific part of the loom which is prone to creating issues, or is it used as a generic description when talking about wiring problems?
I know, I need to get out more! :)
Paul, it's the part of the loom that goes from the body to the boot lid. It is prone to problems. It's on the LHS as you look at the boot by the hinge.
Jack Ratt
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
The main area where the wire breakages tend to be, in my experience with 2 x Z3's anyway, is where the wiring loom is held in place by the plastic clip on the left hand boot hinge.
I actually repaired my silver zed only last weekend. I removed the plastic clip altogether and have tethered the loom to the hinge with a cable tie. I'll take a photo later and edit this post.
In my case 5 of the nine wires were broken and were probably only kept together because they were tightly wrapped in the loom. The only symptoms I had was the intermittent operation of the central locking and setting of the alarm.
It was an easy fix though, only took about an hour all in.
The wires to the upper brake light
Plastic clip removed
Dalek
Z3 2.2i Auto
Thanks Garry. To make my life easier, do you know which colour wire is the third brake light?
Sean d
Lincolnshire
Here ya pal, this was mine, don't know was wasn't working as I openend it up to check
Mario
If anyone is interested there are loom of doom repair kits available on ebay I can look them up if anyone interested. You need to do some soldering but easy enough
Dalek
Z3 2.2i Auto
All fixed.
I have soldered the broken wire back together but I will now order the loom repair kit as two other wires were cut half way through as well.
Thanks everyone, this forum is amazing!
