They are 340 mm long, 300 mm would do. They do not need to be the heavy duty welded closed eye bolts like those shown in the picture, they are what I had on hand. Normal eye bolts will do the trick as the forces are not great. Measure up from the first hole in the control arm and you will get under 300 mm.
