Did it make a noticeable difference?There's also a member on here who fitted a lightweight flywheel to his M Roadster![]()
If you are thinking that a lightweight flywheel is just about losing mass, you really don't understand the concept.Consider instead, if people just need to lose some weight,
far better and much cheaper.......![]()
Yes.Did it make a noticeable difference?
Most people who think about lightened flywheels as saving weight, it is more like an ice skater pulling their arms in so that they can spin faster.it was a joke, professor.....![]()
That's exactly what I do. I wait until something needs to be replaced and then replace it with a better part. A standard clutch is £500, a lightened clutch is £850, so it's only £350 to upgradeNothing wrong with my clutch, even after 130ish k miles but no harm in researching just in case eh?![]()
A DMF is a very good system for the average driver. It dampens the power delivery from the engine to the gearbox. This means that poor clutch operation can be made smoother. It also means that the pulses from the engine can be dampened, thus allowing the gearbox internals to be lighter.It's not just lightness but also the fact that you are going from a dual mass flywheel to a solid single mass one.
so, far i realized. but may be it can be wrong perception.
