antodeco
Hi all,
All my lights work bar my left hand side rear light, left hand side front light, left handside running light and internal light (brakes, indicator, reverse all work fine on both sides).
However, the only way to get them to work is to have no key in the ignition, light switch on and indicator stalk to the right, then all lights work fine.
It's not the parking lights, as left work when stalk to the right. They don't work if the engine is on no matter what setting. Internal light only works with the above sequence too.
Any ideas or suggestions what could be causing it?
Thanks
Thanks
