Leaking roof
D R Oldfield
Barrow-in-Furness
Hi went out over the weekend to start my z3 and found a swimming pool in the passenger foot well , its coming through the soft top material , what the best way to treat the softtop to re waterproof it ?
Duncodin
Pontrhydyrun - in Crow Valley
M44 FrankenZed
With such a lot of water in the footwell you likely have a lot of condensation collecting on the inside of the roof making it look like the fabric is leaking.
I suppose it is possible that the fabric is leaking but please checkout the other likely causes.
Althulas
Banburyshire
M Roadster
Apart from checking the usual spots for leaks if you’re sure that it’s leaking through the actual fabric the barrier in the roof fabric has failed and needs a replacement. As an interim you could try fabisil tent reproofer or Revo or one of the other products but those products will only be a plaster. Maybe once treated it may last a while and use one of those roof covers when heavy rains are expected.
SV8Predator
Z4 E89 2.0 Atacama Yellow / Z3 3.0 Topaz Blue
Condensation will not result in a swimming pool in the passenger foot well. There is an obvious leak, which will have to be discovered by the owner sitting in the passenger seat and a friendly passer-by squirting water onto the soft top with a conveniently-located hose.
It's not "coming through the fabric", it's a leak, through the various joints between window/glass/rubbers, etc.
Duncodin
M44 FrankenZed
I didn't say the condensation caused the puddle in the footwell.
I was suggesting that all the moisture on the underside of the roof fabric is condensation caused by the puddle. The puddle being caused by a bad leak elsewhere ie blocked drains etc.
