@BMBabe leak from the Base of the door is because the membrane behind the door card must be unstuck at the bottom or missing. The water runs down the window and some finds it's way past the seal, this then drips off the base of the winder and because of the door shape some drips onto the membrane and is then supposed to run off and out the drains in the bottom of the door. Sorry but door card off find the gap in the adhesive and either silicone or butyl strip and seal the gap. Will post a pic when the pic is on.
