Looks like I scuffed up something when I did my VANOS seals.
Car fired up fine but was lumpy. No nasty noises from the engine. Just lacking in power and pulsing from the exhaust. Didn't think too much of it at first as I know it needs to get rid of trapped air. But 5 mins later still not right. Diagnostics telling me error 104 intake jammed or blocked. And corresponding error on the exhaust. My initial thought was a dodgy solenoid but I can't believe it would happen on both sides at once.
Engine now turns over but won't start.
Can't quite figure why if the VANOS wasn't working the engine was running so bad. Previously I had a faulty exhaust CPS which was causing the VANOS to be disabled and run in default positions. Engine ran fine like that.
Things worth knowing:
- VANOS rebuild itself went fine. Though I was surprised the pistons weren't a tighter fit. I used a good quality make X8R. And did the piston resizing as instructed
- My torque wrench wasn't clicking where I felt it should (10Nm) when I refitted the piston to camshaft bolts. So I did this by hand. It could therefore be too tight or not tight enough
- I used the VANOS unit itself from a donor engine that I've never run. So I can't be 100% certain it didn't have issues but all looked fine and it seems unlikely
- I used one original solenoid from the car and one from the donor VANOS so I had the two with the least rust. In other words one was an unknown quantity.
- I made a cock-up initially and put the spring on the intake side. I got as far as turning the engine over to circulate oil with the coils out. It turned over for about 0.5 sec then the battery died on me. So I guess I might have done some damage there but when I took it back apart nothing to suggest I had. I'm hoping a dodged a bullet as the battery failed on me
