A dent puller nice
these are quite effective i have a smaller sucker that i use with a glue gun and it works well. Nice present
Did he steal your cig lighter
Well your a 5th there then mate. Keep popping a bit away.900-1,000. Unless I get lucky.
Yes mate. Nasty knocking from the drivers side rear which I'm hoping can he cured at the same time.Is this the rear beam overhaul Dave ?.
No, thats where I put the carrot for RudolphDid he steal your cig lighter
Can't pin point it mate but I'm sure all will be revealed once it's stripped. I'm getting wear on the inside edges of the rear tyres as well so hopefully all will be sorted together.Probably the beam bush dropped right down, like Ant's has Dave.
Looking forward to it mate. I think these things get massively over looked so probably never been done. I am most excitedMine have sank a good un the beam virtually sits on its mount plate which is the reason my suspension geometry is out at the rear should be like a new car when it gets rebuilt
Reggie will be sorted after his surgery![]()
I think we all get the wear on the inside edge mate, especially being loweredCan't pin point it mate but I'm sure all will be revealed once it's stripped. I'm getting wear on the inside edges of the rear tyres as well so hopefully all will be sorted together.
I must also address the rear as the front is all done nowLooking forward to it mate. I think these things get massively over looked so probably never been done. I am most excited![]()
