Is my coolant system bled? No heat at idle
Rod the mod
i had a swine of a time bleeding mine, had to swap the heater hoses round to get rid of the air in the matrix, scared to swap them back now :confused:
Rod the mod
the two heater hoses that enter the bulkhead, just put the top one on the bottom and vice versa
Andyboy
SHEFFIELD
So you've had the heater hose off and filled it with coolant?
Exit needs to be at the top because heat rises.
No, law of physics says heat, rises so that’s how hot water circulates. Goes in at the bottom and comes out at the top.
Delk
Hemsby Norfolk
Z3 3.0T
While cleaning out bits out of the engine bay on mine today I found what looks to be the additional heater pump.
Pingu
That's the water valve. It could be something to do with your problem, as it is operated by the heater knob (as I described earlier). It opens when the heater knob is set above FULLY COLD. It's purpose is to ensure that hot water is passed through the matrix when required, and that the matrix is allowed to cool when set to FULLY COLD.
See page 248 (6410.7-01) of this (http://www.porterbility.co.uk/Files/PDF/e36z3_98_AG.pdf)
