intro
patientpete
Hi People, I am retired and am working on a Z3 1997 1.9 which is in a bad way! It is being stripped down and am working on the rear end.
I have had difficulty sourcing parts from uk. I managed to obtain new sills (entrance panels!).
I want to remove the trailing arm which needs TLC. getting there!
Any parts contacts out there would appreciate.
I removed the rear exhaust and found part of the pipe had been squashed to about half the diameter, so another part to get!
I am in Birmingham and welcome advice etc.
Regards one and all.
Pete
Sean d
Lincolnshire
Welcome to the rear end club, a few of have either done it or are on it at the minute, just done my diff, poly bushing the beam and trailing armsand replacing just about everything else
Pete
Hi Pete, welcome from me near Lincoln. Make sure the exhaust isn't supposed to "flattened" before replacing it. It's common to see this.
ps. Breakers on here, in no particular order are, @spurs fan in a coupe , @mrscalex , @Synclare . All good guys, very helpful.
Also post adds in the Wanted section.
Slam
North Yorkshire
Zedless. Mini GP 1379
Hi and welcome from London
Brian H
Killin
E36/7 3.0i - E85 Z4///M
Welcome to the forum, as Tony states above the exhaust is supposed to be shaped this way, if you do not have this flattened section the exhaust will knock (unless you have an aftermarket exhaust which hangs lower to avoid the knocking).
Mazza
Bognor Regis
Hi and welcome to the forum from Bognor Regis.
Lots of expertise on this site .....anything you need to know just ask.
:welcome:
BMBabe
Staff member
Community Admin
Aylesbury
Welcome from Aylesbury :p
Jack Ratt
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
Hello and welcome to the forum
FRANKIE
American Zeds
Pete
Welcome to the forum from Egg Harbor Township, New Jersey.................Frankie
Shelly
Norfolk
Z4 2.0 20i M Sport sDrive
:welcome: Hi and welcome from me too :coolsteer)
Bazza
Verwood Dorset
:welcome:
Hi @patientpete,:welcome: to the forum from a Brunnie now in Staffordshire. As posted above lots of help and breakers on the forum;)
patientpete
Hi Im all for the rear end club! Your diff looks great. Shame you have to use it because would look awesome in the front room with glass top to use as a table! Im only joking of course!
I have removed l/h rear disc, so am slowly getting there! I can spot some surgery needs to be done so all must be removed.
I intend replacing brake pipes doing my own using kunifer. I wish I had 2 workshops!
Cheers thanks for help.
Synclare
Staffordshire
Hi, hope you're having fun with it. I'm local to you near Birmingham, any parts needed just ask, quick squirt up the A446/A38!
