Here is the link Tony with part numbers.
http://bmwfans.info/parts-catalog/Z...M52/R-N/browse/bodywork/side_panel_tail_trim/
A few new pumps in this link http://www.carparts4less.co.uk/fuel-pumpIf you have a Euro Car Parts or Andrew Page depot near you they should be able to supply you with the pump/motor to replace yours. It will more than likely have a Bosch part number on it to identify it with. If so even GSF worth a try. Personally I wouldn't fit a second hand fuel pump because they're not too easy to change. But that's just me.![]()
Could you be seeing the ground (earth?) on the filler neck?@t-tony ...
While in there I noticed that there is another non-connected wire that seems to be part of the stereo amplifier mounted to the chassis near the fuel cap area. I could not see where it is to be connected. hmmm.
I believe Cooper is talking about the fuel cap cover locking mechanism. He mentioned his wasn't working a few posts ago iirc, ;-)
That's correct @Sailorbaz , I kind of jumped in with another issue and it may have confused some people regarding the original problem this thread is about.I believe Cooper is talking about the fuel cap cover locking mechanism. He mentioned his wasn't working a few posts ago iirc, ;-)
Does that mean that you wear crown in bed, or just a Christmas hat?......Sorry, I'm still Imperial.
