Silver Baz
Are all the fuel filters the same for each model ?
Any tips on changing the diff and gearbox oils (I don't have the luxury of a lift or pit!)Unscheduled (supposed to be lifetime) = gearbox oil + diff oil
Thank you Tony, one more simple Q: which side of the gearbox are the drain and filler plugs and do these have replaceable washers (OK that's two Qs!)You will need a decent jack and a pair of axle stands. Also make sure you can remove the filler/level plug on the Diff. and the gearbox BEFORE draining them. Easy to refill using a small funnel and 2mtr of garden hose.
Warm the oil and remove the filler plug before you remove the drain plug.Any tips on changing the diff and gearbox oils (I don't have the luxury of a lift or pit!)
Interesting. The ones I have just bought (based on BMW online parts finder) have what looks like a rubber/plastic o-ring fitted ............However the drain and fill/level plugs on the Diff. do have soft alloy sealing washers.
Oil in those spark plug wells is a sure sign of the central plug well gaskets failing, they go hard and brittle and allow oil to seep into the wells. Probably time to take the cam cover off and put a new gasket set on if there was oil in there it will seep in there again with the old gaskets left in place.We found the 3 back spark plug holes contained excessive oil. Because of this excess oil, we put 4 new spark plugs in from the front and 2 old spark plugs in the 2 back spark plug holes. Tony then sprayed brake cleaner in the 2 back spark plug holes and blew the brake cleaner out with a compressor.
To answer your question there is two types of fuel fitler for the z3.Are all the fuel filters the same for each model ?
