How on earth would that get into the tyre, it would have to been stood upright to penetrate at that angle.
I have no live rounds or empty cases in my possession ........... oh, hang onWell done to everyone who said it was a bullet View attachment 34384scary thing was that it was still live
You can say that about almost anything which stick in tyres. For example, if you drop a screw on the floor how likely is it that it will fall on its head standing straight up?, but they nearly always go straight through a tyre as if you had put it there with a screw driver!How on earth would that get into the tyre, it would have to been stood upright to penetrate at that angle.
Screws and nails flip up when you catch the edge of the head and then dig into the tyre.You can say that about almost anything which stick in tyres. For example, if you drop a screw on the floor how likely is it that it will fall on its head standing straight up?, but they nearly always go straight through a tyre as if you had put it there with a screw driver!
That's simply amazing Andy.Not a bullet in a tyre but this was found in a WW1 battle field, two bullet's having collided in mid air.
There are others one from the battle at Gallipoli
Andy
Now that's a picture and then some! I would say what are the chances but there was plenty of it flying around. Impressive pic nonetheless.Not a bullet in a tyre but this was found in a WW1 battle field, two bullet's having collided in mid air.
Andy
The question is, is the distance that the head has to travel sufficiently small that the pressure doesn't have time to dissipate into the tyre before the head cracks the hub. My guess is the head hits the hub before the tyre has time to explode - which it will just hundredths later. Double whammy!So, lets think about the possible outcome of the bullet in the tyre.
If it is a .223 which I think is the smallest round available in that style of case.
The head or bullet itself will weigh between 3 and 6grams depending on type, (0.125 to 0.25 ounces). Not a lot really, however it would leave the case at around 3000 ft per second and is about a foot away from the wheel hub.
If you was lucky, it would go bang while the case wasn't in contact with the ground, so the case would force itself out of the tyre. However, its only likely to go off when it is flat against the road!
As the powder ignites in the case, it will generate between 50 and 65 thousand psi on the back of that .223 diameter bullet to force it on its way. A tiny surface area, but still a huge amount of instantaneous energy.
So the question is, what happens first?
a) tyre instataniously shreds due to the rapid pressure increase inside the already damaged tyre
or
b) does the wheel hub shatter as the head travelling at 3000 ft per second hits it?
we won't consider where the bits would go.
driver has had a very lucky escape!
Have had no end of screws and nails in tyres over the years. If it tips up so the point sticks into the base of the groove I can see how it then gets pushed through the tyre. I see a PhD subject hereStill hard to see how it would tip up enough to point hold Ian, a cylindrical object like that you would expect it to get rolled away. Just a freak chance. I wonder how many more are out there?
Tony
No Mark, nothing I/we can do, if a customer wants to take a dangerous vehicle away all we can do is advise against it. Even on a vehicle which fails the M.O.T. the same applies.Did you have to inform the police for that Tony?
